interior lights
My interior lights on my eclipse are orange and I just dont like it. Is there any way to change the color??
RE: interior lights
not exactly sure what you mean... dash? or like your over head and stuff? just get new bulbs. I don't know why they would be orange.. usually all interior lights are white unless you change them. and if its the ones on your dash, get a reverse glow/indiglow gauge set
RE: interior lights
The lights are the ones in the dash and under the dash. The ones under the dash come on when I open my door. The ones in the dash that I am talking about are my guages which I know I can change those ones. The ones I want to change are the ones that I want to know if I can change are the ones that light up the A/C button, the knob to adjust the A/C or the heat ect. I am also pretty sure I can change to ones under the dash pretty easly too. Thanks for your reply and I hope this cleared up my question a little more.
RE: interior lights
oh, yeah, you can get HVAC overlays in white and blue.. not sure about other colors.. but yeah, check out ebay, and interior, HVAC or gauges.. you can get clear knobs and stuff too so they light up.. its actually pretty cool. adds a lot to the interior
RE: interior lights
I've seen red glow gauges which I thought were kinda neat. I'll have to check out the hvac stuff, that does sound cool.
RE: interior lights
I changed my HVAC controls and my ring around the ignitions and the cigarette lighter to change to blue. It is a very simple process if you can solder. You can get the LED and capacitators at Radio shack.I'll see if i can get a part # for you.
RE: interior lights
Someone told me that the orange color came from a rubber thing around the bulb. Is that actually true? Could you just pull that off then and put on a replacement color? Kind of like condoms for light bulbs, ha ha ha.
RE: interior lights
I've seen sets of common sized colored bulbs at some parts stores so you can replace things like dome lights and whatnot with different colors.
RE: interior lights
well the 2g's do, but thats just on the floor lights. The car in your pic is a 3g, i have no clue about these cars. Im sure that it it the same you jsut pullthe bulb out and replace it with another at like practically any store walmart, autozone. And you can jstu take the the bulb into the store with you and find a matching one of different color, you could jsut buy the bulb sleve or "condom" but i think that the color look alot better if you get a color bulb. Hope that helps
RE: interior lights
If you go to say Optix or Street Glow or something like that, you'll be able to plug in your vehicle and then they'll have all the lights listed that you can possibly change with a part number. Either order it from them or take the part number and shop around. If you have no luck with some of the lights you can just disconnect them and wire in new LEDs in place, obviosly not the best solution but I've seen it done.
| All times are GMT -5. The time now is 02:16 AM. |
