96 eclipse window regulator help
Old Jul 24, 2007 | 06:25 PM
import tuner's Avatar
Default 96 eclipse window regulator help
hello everyone. i have a problem with my pass side window regulator. the motor works if i put direct power to it. it won't work at all off the pass side switch or the master switch, but the drivers side does work. is there a relay for each window or maybe a fuse? ive already tried different switches but no change. can any help? thanks.
Old Jul 24, 2007 | 11:33 PM
98gstspy's Avatar
Default RE: 96 eclipse window regulator help
did you check all of the wiring to the window and the switch i had the same problem in my spyder. it was a small cut buy the door. all it needed was a little electrical tape and it was fixed.
McNeil
May 28, 2009 09:05 PM
ajan246
Sep 21, 2007 04:56 PM
tjbiker031
Apr 4, 2007 11:52 PM
ajav05
Aug 23, 2006 08:21 PM
gersrt
Jan 16, 2006 07:23 PM
