amp wiring question?!?
Old Sep 19, 2007 | 07:39 PM
96420ars's Avatar
Default amp wiring question?!?
ok so i just bought a 600w amp and me and my friend were talkin bout how to wire it up and we kno how we just dk where to run the wires through under the dash to get them to the battery, ne suggestions on where to run them through??
Old Sep 19, 2007 | 08:33 PM
jason clipse's Avatar
Default RE: amp wiring question?!?
find where wires go thru the firewall and go thru there then go along the door under the carpet then back to ur amp
Old Sep 19, 2007 | 08:38 PM
jpmontero98's Avatar
the + bat cable has to go through your fire wall (driver side steering coloum or somthing)ur gonna have to drill a hole and put in a rubber insert...but paint over the drilled hole so it dont rust
Old Sep 19, 2007 | 08:39 PM
ORIGINAL: jason clipse
problem with that as my friend found out it shorted out some of the wires...i guess it depends on the wires and car
Old Sep 19, 2007 | 08:40 PM
yea u got to have nice thick coating on the wires aka good quality wires
Old Sep 19, 2007 | 09:02 PM
96420ars's Avatar
yea, alright well thanks, that helps, yea we knew we needed to do somethin like that with drillin a hole but we just werent quite sure bout where and all, we kno where to run the rest of the lines tho, thats the easy part but yea i guess well try and figure that out this wkend then and c wut happens
Old Sep 19, 2007 | 09:09 PM
Kaede.Noir's Avatar
rubber for sure, or else the metal will scrap the cables off.... paint it for the oxide, and there on the firewall theres a circle, you can drill on that circle safely
Old Sep 19, 2007 | 09:18 PM
96420ars's Avatar
alright, thanks for more info, yea i went and looked earlier today just to kinda look around under there and yea i actually do remember seeing that circle down there, but ya, got it, drill it, paint it, rubber insert, good to go [8D]doenst seem too terribly difficult
Old Sep 20, 2007 | 06:45 PM
make sure u check both sides.........you dont want to hit anything important
Old Sep 21, 2007 | 08:49 AM
96420ars's Avatar
wut r u talkin about, of course i wanna hit somethin important nahhh, yea def gonna check both sides before i do ne of the drillin
