Battery
Old Mar 9, 2021 | 08:04 PM
Paul17's Avatar
Default Battery drain
Hi everyone I have a 2013 Mitsubishi rvr and I have a very bad battery draw basically I'm getting 0.135A of draw which is causing my battery to die once a week or sometimes once a month it varies I have disconnected every fuse and relay inside the engine compartment and I end of the draw does not drop it stays consistent any help would be very much appreciated thank you very much I am located in Canada that means anything
I have isolated the draw to the fusible link and one of the cables that 80 amp cable is drawing however I do not have wire diagram so I do not know where that any amp fusible link goes to
waid302
May 8, 2021 01:14 AM
bmerz
Feb 24, 2021 06:55 PM
SERPENTOR
Jan 11, 2017 11:23 AM
darkman0127
Oct 27, 2004 10:33 AM
motaz
May 18, 2004 09:34 AM
