ignition switch diagram
Ive been looking everywhere and cant find one. Even just a crude pic someone made in paint would be helpful. Im still tryin to figure out how to hook up my switch-ignition system. A switch to go into accessory, a switch for on, and a button for ignition. I just need the diagram. I can see from the cylinder in front of me that theres 6 points for wiring:
IG2 - AM
ST - IG1
ACC - R
I get that ACC is accessory, but why are there 2 ignitions? is one a ground? and wtf are AM and R?
IG2 - AM
ST - IG1
ACC - R
Okay so when I went to switch out the lock cylinder (where the key goes) you have to remove the ignition switch, and in doing so it got dropped and now a couple springs wont line up inside. I put it together to try and see if it worked and all it did was grind, no response from the car at all. I need the diagram now, not just want it. The key wont work I have to find out what of the 6 wires control accessory, on and ignition. Ive tried looknig everywhere but In mot seeing anything
TE you always have info for me please help asap I cant turn my car over at all not even put it on accessory
Okay so I finally found some info in the haynes manual of all places, it didnt give me a diagram that told me what wire was what, but it did have a continuity chart. With that I found out what was controlled with each wire by supplying power to each one. using that I was able to convert the multiswitch of a factory key ignition to individual switches. Now I no longer need a key, I can flip a switch and push a button and the car will turn over. I will have a proper writeup and possibly pictures soon.
So yea, I no longer need that diagram/info I asked repeatedly for.
Hello 3000gt16
It happens to me, the same to you.
My Ignition Switch is broken, the Mitsubishi Dealer delay 90 days to bring me the part.
I want to guess how can I connect to 3 or 4 manual switch and a start button but I not know how. I search a Lot in the Web, but I don't know how to join the wires.
I look the manual and I have 4 states.
1 2 4 5 6
Lock
Acc X X
On X X X X
Start X X X
But I dont know how to match Wire colors with terminal numbers.
My Connector appear like this
ST IG2
X X
X X
R X AM
IG1
Can yo Help Me?
Sorry for my english.
Best regards
Gustavo
1 2 4 5 6
Lock
Acc X X
On X X X X
Start X X X
ST IG2
X X
X X
R X AM
IG1
Can yo Help Me?
Best regards
Gustavo
callingdoug
May 25, 2015 03:11 PM
allallyouyou
Feb 12, 2012 11:13 PM
