Leds..
Old Jan 2, 2009 | 10:23 PM
zero_Wheeler's Avatar
Default Leds..
so i got a set of green leds for my 98 gs, and ive got them all mounted right, its just the wireing. seems like the only place the connectors will meet and connect right its right under the drivers seat, but the only way i can figure out how to run the wires is if i drill a hole int he floorboards..
should i and just try sealing the holes? or is there any other way to run the wires through the interior?
Old Jan 2, 2009 | 10:53 PM
Dusty Eclipse's Avatar
Default RE: Leds..
Yes, thru the firewall. Look by the drivers foot area. Its a rubber stopper. If you cant use it for whatever reason, you can always do the ghetto ways of thru the fender/door or thru the steering column. Niether of which are really a great idea.
Old Jan 2, 2009 | 11:13 PM
Default RE: Leds..
i checked by the foot area and the only place i could find was thought the hole the power wire went threw for the amp.
and it doesnt matter anyways because the cord for the rear led tube wont reach the firewall, itll only make it to the seat area..
Old Jan 3, 2009 | 01:38 AM
Default RE: Leds..
You can extend the wire and put it beneath the carpeting. You can use the same hole the amp wire is using. Or even put a little dist. block in there.
Old Jan 3, 2009 | 11:15 PM
Default RE: Leds..
extend the wire?
sorry idk..
Old Jan 4, 2009 | 05:49 PM
Lil Evo's Avatar
Default RE: Leds..
extending a wire isn't really rocket science. you can solder or use a barrel connector. I recomend solder and using shrink tubing over the connection, go through the firewall, same gromet that the amplifier wire is run through and run the wiring underneath the carpeting.
theiss2200
Jun 27, 2008 06:22 PM
MrPink
Aug 22, 2007 06:35 PM
mitsuant
Dec 20, 2006 10:43 AM
EvolutionX
Nov 10, 2006 05:43 AM
nate5023
Dec 3, 2004 01:10 PM
