Need help with dome light
Old Nov 19, 2008 | 03:58 PM
winggiang90's Avatar
Default Need help with dome light
which wire is the one to the dome light? i have a 2002 lancer and the wire is missing on the roof.
Old Nov 21, 2008 | 01:09 PM
BEAT's Avatar
Default RE: Need help with dome light
It should not bemissing it must be tuck inside the cloth or upholstery. take the cover off with a small flat screw driver.
pop it out and you will see bulb the wiring should be inside the panel. if you want to unscrew the housing that holds the Bulb it should be there.
probably the previous owner had a short and never bothered to fix the bulb and wiring.
joeba
Jan 12, 2012 08:40 AM
suninthyhands532
Apr 4, 2009 03:37 AM
tareks
Feb 11, 2009 12:50 PM
knockout509
Aug 14, 2008 06:35 PM
azt021
Apr 8, 2008 10:27 PM
