Need to tap into a live wire
Old Nov 25, 2010 | 12:41 AM
jdohe's Avatar
Question Need to tap into a live wire
I have a 2002 Mitsubishi Galant.
I need to power a hidden gps locator in the car which is something like a lo jack. It requires between 5v and 12v and preferably a wire that is always live.
It comes with a kit that has a fused set of wires, red and black. I assume the black wire should get attached to a bolt on the chassis, while the red wire splices into a live wire or harness port.
So far, the best wires for this seem to be behind and below the glove box. But... WHICH wire? I don't want to go setting off the car alarm or air bags.
I do have a multimeter, but I don't want to go cutting into wires, randomly guessing at which one will have live power.
Old Nov 28, 2010 | 09:14 PM
3000gt16's Avatar
If you want you can always go right to the battery, theres bound to be a grommet you can fit the wire through in the firewall.
Old Nov 29, 2010 | 05:59 AM
jdohe's Avatar
Default That would work.. but...
It would have to be hidden better than that. The car is frequently at a mechanic because the car is a lemon. One thing after another goes wrong with it. I'm pretty sure the mechanic would spot that.
I did poke around with my multimeter a little. Unfortunately all I accomplished was making all the power locks in the car go nuts everytime I would poke a wire with the multimeter.
Old Dec 5, 2010 | 10:12 PM
3000gt16's Avatar
If youve ever looked at a universal fog light kits wiring harness, you have to go from the battery thru the firewall to your switch. If your mechanic will have a problem with that, theres a constant live wire fo memory to your radio, you could tap that. If you have an aftermarket radio, its the yellow wire.
jdohe
Dec 12, 2010 07:00 AM
Natedogg89
Jan 29, 2008 06:24 AM
faded2
Jan 19, 2006 08:43 AM
GT N1nj4
Aug 29, 2004 07:02 AM
1rippinGT
Apr 2, 2004 04:21 PM
