No signal lights, no fog lights when engine is on
Old Dec 27, 2024 | 12:49 PM
abancelle's Avatar
Default No signal lights, no fog lights when engine is on
Hello everyone! Would just like to have your inputs on this issue I encountered just now on my 2011 RVR.
Here's the situation. . .
When the engine is turned on, the signal lights are not working be it left or right, the fog lights are not working as well. The headlight is on but only the low beam as the high beam isn't working as well. On the dashboard, signal icons won't turn on be it left or right, fog lights icon won't turn on, high beam icon won't turn on, but the headlight icon is turned on and which won't turn off. Also, all signal lights are working when the hazard button is clicked on, so with both the signal icons on the dashboard
Yet when the engine is off and the key is placed in the "ON" position, everything works fine. All lights and signal indicators are working as they should.
Given these, any idea what may be the problem is?
Thank you.
ExplorerOrca
Dec 12, 2015 10:23 PM
caskey_b
Oct 11, 2015 07:54 PM
Texas001
Mar 30, 2013 04:32 PM
Jims M
May 1, 2011 07:52 AM
gotzenjoi
Dec 1, 2007 11:53 PM
