OEM Stereo Wiring Guru's
Old Sep 2, 2007 | 09:25 PM
thejones10's Avatar
Default OEM Stereo Wiring Guru's
Ok, plain and simple, is there any possible way to add an Audio input on the OEM Infinity stereo unit in my 04 Endeavor XLS with the 6CD changer bult in? I see there is nothing plug and play so I assumed that someone has cut and spliced to make it work.Please tell me I can take a 2.5mm Headphone output and splice it in the theHead or AMP harness somewhere to make this work?
Old Sep 6, 2007 | 03:10 AM
50ul }{4ck3r's Avatar
Default RE: OEM Stereo Wiring Guru's
I Think Not!!!!
Old Sep 6, 2007 | 10:57 AM
Dusty Eclipse's Avatar
Not... really...
Old Sep 11, 2007 | 11:46 AM
Lil Evo's Avatar
definetly not
EDIT: The only option that jumps to my mind is if you're trying to connect an iPod. In that case, an iSimple might work. It's a bit of a pain to install, but basically what it does is duplicates the signal of the cd changer and essentially tricks the head unit into running your iPod. Down side is, the cd changer is no longer functional.
toysfreak
Apr 13, 2012 12:01 AM
PeKtO
1st Generation
Sep 22, 2008 03:34 AM
darvo
Apr 17, 2008 02:45 AM
Sanguinius
May 16, 2006 08:23 PM
Toohey
Jun 29, 2005 04:20 AM
