Problem
Old Feb 7, 2008 | 04:54 PM
stephengrossman's Avatar
Default Problem
Well I was jump starting my car the other day and It got jumped fine. but after I jumped it i started up my aftermarket cd player and it went for like 1 second and turned off. the clock does not work either since whatever happened happened, and same with the clock. So the clock, cd player, and auto door locks dont work... my check engine light is on ( i think thats an o2 sensor tho)
does anyone know the problem? I checked ALL the fuses and they are all good. and when the keys are in the ignition and the door is open it doesnt make anoise anymore.. anything will help. thanks.
Old Feb 7, 2008 | 05:22 PM
Default RE: Problem
You check the fuse box under the hood and the one by your feet?
Old Feb 8, 2008 | 06:24 PM
Default RE: Problem
yes i did. all fuses are good.
I also called the dealer, and they said it could be a 100amp fuse in the engine bay but i have no clue where they are talking about.... like if it was in a fusebox or not cause i sure didnt see any 100 amp fuses in the fuse box. but yes all of the fuses in both boxes are golden.
Old Feb 8, 2008 | 06:36 PM
Default RE: Problem
or maybe like a fusable link somewhere?
Old Feb 8, 2008 | 06:41 PM
Default RE: Problem
You say you checked all the fuses...
Old Feb 10, 2008 | 06:41 PM
Default RE: Problem
yep, all the fuses are all good underthe hood and under the dash
