something is draining my battery and i replaced lots of stuff
Old May 4, 2006 | 04:56 PM
micahman's Avatar
Default something is draining my battery and i replaced lots of stuff
i have a 91 talon and it has a new motor in it and the lights were pulsating and there was a squeel on statrup and one day my battery went dead. so i bought a new alternator and threw it on and i didnt have the pulsating any more and no squeeling. i drove it about 60 miles to work shut it off and then the car wouldnt start. it was dead. waited about 4 hours then i tried starting it again and it barely strted. bought a new batery and it did the same thing over again. what should i check next or how can i find out how to find out where my batery power is going?
Old May 4, 2006 | 04:58 PM
micahman's Avatar
Default RE: something is draining my battery and i replaced lots of stuff
also i was wondering if you have your car running should it still run with the batery disconected?
Old May 4, 2006 | 06:20 PM
magnet's Avatar
Id be looking for a bad connection or a weak starter. I have a S10 that one time did that same ****. Ended up being a bad connection on the starter. As far as the car being able to run when the battery is unhooked, Im not sure. Good luck.
Old May 8, 2006 | 02:03 AM
90eclipse_gs's Avatar
no your car wont run without the battery i had a 95 plymoth neon that i blew the fusible link for the charging system and i got like 1,000 feet down the road
Old May 10, 2006 | 02:16 AM
05Wishitwasanevo's Avatar
you might wanna check your connection from your battery to your starter maybe a soleniod or something probably not the starter but bad connections check for rust and corrosion and check your wires see if they need replacing
sidclaim
Jun 12, 2013 05:13 PM
gstgurl
May 13, 2009 08:33 AM
EMonz57
May 14, 2008 08:45 PM
DragonRacerX666
Jan 30, 2007 12:47 AM
Montero Momma
Jan 5, 2007 11:00 PM
