| Lil Evo |
Feb 13, 2009 11:05 PM |
RE: Switching radio's
you'll need a new harness. Mitsu's are completely different from your teggy, but honestly the install is a piece of cake. the radio bezel is held on by pressure clips only, so give it a gentle tug and it should come off relativley easily. you can unplug the cigarette lighter or just lay the bezel out to the side. There will be a few screws holding the radio in, just remove and presto, the radio is out. you can either use the factory mounts and do what's called an ISO mount the unit, or you can mount the cage to the radio bezel itself.
