Turbo ECU on no turbo car
I have a 92 GS that im about to turbo.... everything is stock from a 90 turbo laser... can I just plug in the turbo ecu and play or is there more to it?
RE: Turbo ECU on no turbo car
Im gonna say theres more to it.
Does anybody know what more there is to it?
like a whole turbo steup ...duh ricky
LMMFAO!!! |
I dunno if the computer works the same.. I heard that theres some pins that are different
well its possible to rewire that !!!
I think they use totally different even harnesses...
I mean all u did was add a turbo to a n/a car? |
no he wants to..
I think things like the MAF gotta be changed too.. **** like that. Sensors and whatnot. Though my experience and work with 1G N/As is limited.
Well, if your just adding a turbo onto your gs wouldn't your stock ecu be fine, as long as you get an afc, or get dsmlink? But if your swapping a gst/gsx in it then it should work, because you'd be changing the whole engine wiring harness too, and the interior one im pretty sure is the same, although not quite sure tho
