Turbo ECU on no turbo car
Old Dec 20, 2007 | 11:11 PM
Clipse1's Avatar
Default Turbo ECU on no turbo car
I have a 92 GS that im about to turbo.... everything is stock from a 90 turbo laser... can I just plug in the turbo ecu and play or is there more to it?
Old Dec 20, 2007 | 11:19 PM
Dusty Eclipse's Avatar
Default RE: Turbo ECU on no turbo car
Im gonna say theres more to it.
Old Dec 20, 2007 | 11:23 PM
Clipse1's Avatar
Does anybody know what more there is to it?
Old Dec 21, 2007 | 12:53 AM
50ul }{4ck3r's Avatar
like a whole turbo steup ...duh ricky
LMMFAO!!!
Old Dec 21, 2007 | 01:08 AM
Clipse1's Avatar
I dunno if the computer works the same.. I heard that theres some pins that are different
Old Dec 21, 2007 | 01:11 AM
well its possible to rewire that !!!
Old Dec 21, 2007 | 01:34 AM
I think they use totally different even harnesses...
I mean all u did was add a turbo to a n/a car?
Old Dec 21, 2007 | 01:48 AM
no he wants to..
Old Dec 21, 2007 | 01:53 AM
I think things like the MAF gotta be changed too.. **** like that. Sensors and whatnot. Though my experience and work with 1G N/As is limited.
Old Dec 22, 2007 | 08:39 PM
lhausi2's Avatar
Well, if your just adding a turbo onto your gs wouldn't your stock ecu be fine, as long as you get an afc, or get dsmlink? But if your swapping a gst/gsx in it then it should work, because you'd be changing the whole engine wiring harness too, and the interior one im pretty sure is the same, although not quite sure tho
