Turbo Timer Install
Old Aug 30, 2006 | 09:46 PM
rodrigo.diaz3's Avatar
Default Turbo Timer Install
i want to install a turbo timer on my evo 9 but i have the evo 8 ecu pinout can i use this pinout to install it i know is not the same ecu but to install the TT i think there will be no problem i think???
My TT is the FATT blitz
Old Aug 31, 2006 | 11:45 AM
XTREME's Avatar
Default RE: Turbo Timer Install
ORIGINAL: rodrigo.diaz3
No, you can't use the Evo 8 pin chart to install the Turbo Timer. I also have a Turbo Timer and have been attempting to install it in my Evo 9. I found a pin chart people say matches even though colors don't line up. I decided not to use it because of the color problem and have been looking for a correct pin chart with no luck so far. If you want the pin chart that is supposed to be correct I can post it here and you can choose for yourself.
Old Aug 31, 2006 | 12:03 PM
XTREME's Avatar
Here ya go!
[IMG]local://upfiles/7195/45E3FCAE4903493DB76ADD640686557B.gif[/IMG]
Old Aug 31, 2006 | 01:44 PM
Ok thanks a lot i will try.
endlesskustumz
Mar 29, 2008 12:23 PM
evilevo
Sep 20, 2007 07:09 PM
Xv7vX
May 25, 2007 01:48 PM
BrunoBoy650
Feb 8, 2007 08:53 PM
patfan7452
Aug 21, 2005 08:10 PM
