Wiring 88 Pickup Build date aug 88 Radio MB649827
Old Mar 25, 2012 | 12:13 PM
88pickupaust's Avatar
Default Wiring 88 Pickup Build date aug 88 Radio MB649827
Hi, I'm in Australia and have the local model called a triton MF but it's a mighty max in America.
VIN JMFMF3M227JJ001440 Jan 89
It has extensive wiring problems which I have worked through successfully.
The radio harness has been cut out of the wiring loom.
I need a wiring diagram for this vechile or similar.
I have a mitsubishi radio from the era. MB649827 AR-4325 3410107
Need the pinouts for this
The vehicle appears to have comon neg speakergrounds.With 2 wires in the loom blue/white which give 6 volts all the time, when acc or run at least one gives 12 volts. Possible both do ?
these are the wires that work and what they appear to do White/Blue L/F
Black/Blue L/F Black/Red R/F and of course the 2 blue/white power 6v/12v
|__|__|__|__|__|__|__|__|
Representation MB649827 Mitsubishi Radio
- - - - Pinout block rear of radio
My interpretation starting at left top pin 1 through to 2nd line last pin 16
6v/12v wire operates radio Pin 2 and 8 Red/Black R/F Pin 13
Black/Blue pin 5 White/Blue L/F pin 3
The radio goes but does not turn off until ign off
I have 1 Blue/white 2 green/white 1 black wire left over in the wiring loom.
I cannot find the constant wire 12v+Red/Black do the 2 blue/white add up to 12v when both attached. say to pins 2 + 8
I don't have any other clues.
Another problem I have is locating the main fuseable link. I found a u shaped wire in the engine bay red with black fuse in the centre. Where does this go.
The vehicle had been run by the previous owner with the coil and headlights directly off the battery.
I have had the vehicle ruinning, after rewiring the coil etc replacing subfuseable links
Everything is going now except headlights and horn.
Can you help.
P.S. I'm glad I didn't run into this vehicle when a teenager !
Old Mar 27, 2012 | 10:09 PM
The text editor eat my diagram.
The vin probably isn't correct either as I may have swapped numbers for letters 0 O
These are the wires that work and what they appear to do White/Blue L/F
- - - o- o------o-----o--o-
------------------------------------Representation MB649827 Mitsubishi Radio
--------o--o---------o--o----- - - - Pinout block rear of radio (o=Pins)
I figure the front of the vin is correct. Will have another go at reading it.
Old Mar 27, 2012 | 10:26 PM
Default Addendum more going
Build AUG 88
Budget cheap as I already have most everything maybe $20 for a harness
VIN JMFMF3M27JJoo144o Jan 89
I need a wiring diagram for this vehicle.
The vehicle appears to have common neg speaker grounds.With 1 wire in the loom blue/white which give 6 volts all the time,
when acc or run it gives 12 volts.
Black/Blue L/F Black/Red R/F and of course the 1 blue/white which powers 6v/12v
- -- o- o-------o-------o--o-
---------o--o-----------o---o------Pinout block rear of radio (o=Pins)
6v/12v wire operates radio pin 8 think pin 2 is ant Red/Black R/F Pin 13
The radio goes but does not turn off until ign off.
1 Blue/white to the gigarette lighter 2 green/white Illumination
1 black wire left over in the wiring loom. When the lights go on it shows 9 volts
I cannot find the constant wire 12v+Red/Black So ihave built 1 off the loom.
Everything is going now. Except lic plate and 1 parklight and the instrument night light.
Thank-you
Last edited by 88pickupaust; Mar 28, 2012 at 11:00 PM. Reason: More accurate information remove texter errors
jrmdir
Apr 10, 2009 08:16 PM
EMonz57
Dec 5, 2007 07:29 AM
Radialman4360
Sep 7, 2007 12:16 PM
zontarh
Mar 9, 2007 11:46 PM
ratjack
May 3, 2006 06:47 PM
