Internal Lounge Chat about beefing up your insides here.
4g63t engine swap
Old Oct 7, 2008 | 08:15 AM
NYKID's Avatar
Default 4g63t engine swap
i want 2 put the 4g63t in my 96 galant wat is the best setup 4 that swap
Old Oct 7, 2008 | 11:09 AM
Default RE: 4g63t engine swap
first off which engine do you have in the car right now. Because I doubt it would even be possible if you have a V6. Even if you have the 4g64 in the car right now, you might be better off just turbocharging the engine you have.
Old Oct 7, 2008 | 08:47 PM
NYKID's Avatar
the engine i have is stock i havnt done any thing 2 it but i would like 2 run the 4g63t but if there a batter 1 let me kno
Old Oct 8, 2008 | 06:37 AM
i was askig which model galant you have. Do you have a 4cyl or V6
Old Oct 8, 2008 | 07:53 AM
NYKID's Avatar
i have a 4 cyl 2.4L
Old Oct 8, 2008 | 10:21 AM
then if it was me i would just work with the engine you have. You have a very capable engine. If i remember those came with onlya SOHC so you can easily update that to the DOHC from a 4g63. And most of the stuff from a 4g63 will bolt up like the exhaust manifold, ect. You will just save alot of aggrivation from dealing with a swap where things might not line up and then you have to deal with the engine harness.
Old Oct 8, 2008 | 10:39 AM
NYKID's Avatar
well my homeboy said that the exhaust manifold dont not bolt up with the engine i have so wat should i do
Old Oct 8, 2008 | 04:42 PM
silvercoupe97's Avatar
What TE is referring to is this...
http://www.extremeevolutions.com/4G64_buildup.htm
I agree too. If you've got the 2.4 4g64, this is your ticket to have a strong motor.
Old Oct 8, 2008 | 09:11 PM
NYKID's Avatar
but i dont have a 4g63 motor i have a stock 2.4L i want 2 put the 4g63 in my car
Old Oct 8, 2008 | 10:03 PM
ORIGINAL: NYKID
I think you misunderstood us. You can pair up the 4g64 block with a 4g63 head. Doing so, will alleviate a lot of headaches, not to mention it will be a more efficient swap.
