6G7 Engine Guru's Please Help....
What are the diferences between the 6G74 and 6G75 engines??
What car comes with the Dohc Mivec 24 valve V6 Head?
Can the 6G75 internals 3.8L fit on the 6G74 3.5L?
Do you have a web page of original Mitsunishi parts that tells you the part codes between all parts of the engine?
Maybe I could figure out if the 3.8 crankshaft fits with the main bearing codes and rod engine bearing codes?
Thank You in advance
