Internal Lounge Chat about beefing up your insides here.
Advice anyone?
Old Jul 14, 2007 | 11:04 AM
mcnaboe007's Avatar
Default Advice anyone?
Question for anyone? I have rebuilt a 95 mits. eclipse gs - all wiseco pistons 10-5-1 compression - changed all parts with new - recently continued with all new valve job - new valves and all that - car is all put back together - runs hot on exhaust side of cylinder #2 - all has good compression , all has proper fuel pressure , spark good , coil pack - good. I am stuck -- exhaust side - cyl #1 temps at 320 cyl#2 @ 520 cyl#3 @ 320 cyl #4 @ 320 --- please help --- show coming up in three weeks.
Old Jul 16, 2007 | 08:34 AM
RCJr9186's Avatar
Default RE: Advice anyone?
wow. now that's wierd...i honestly can't think of anything except mabey a clogged injector so its causing it to run lean i.e. hotter... i'd run some fuel cleaner in there and wouldn't drive the car to much w/ it doing that... w/ high temps like that you can easily crack a piston, throw a rod. and a lot of other bad things.
JENNE527
May 26, 2006 01:01 AM
91eclipse
Jan 28, 2004 05:36 PM
JonnyBlade21
Dec 13, 2003 05:12 PM
seizure
Oct 29, 2003 03:59 PM
drdan
Oct 13, 2003 07:14 PM
