-   Internal Lounge (https://mitsubishiforum.com/forum/internal-lounge-24/)
-   -   ESi vs. RS (https://mitsubishiforum.com/forum/internal-lounge-24/esi-vs-rs-6532/)
Veritas Oct 31, 2005 05:44 PM
ESi vs. RS
Well, I've been searching for either a Talon or Eclipse and I finally found a nice ESi in my area. Since both engines are the same, I would assume that the parts I looked up for the Eclipse RS I almost bought would fit on my ESi, but I wanted to make sure. Even if they didn't bolt on perfectly, I'm sure it would only take minor modifications. Here is what I was planning on slapping on the engine:
-K&N Air Filter
-Injen RD Cold-Air Intake
-GReddy Evo 2 Cat Back Exhaust
-GReddy 4-1 Headers
-Venom Intake Manifold
This **** fits the RS, but I can't find it for the ESi, will it still fit? I'd like to know before I make the purchase, any help would be greatly appreciated.
player69x Feb 11, 2006 10:35 AM
RE: ESi vs. RS
yea the parts will fit there the same engine.
Evil1993Eagle May 16, 2006 08:26 PM
RE: ESi vs. RS
ORIGINAL: player69x
Yep same engine, pretty much same car.
paintballproam Jul 31, 2006 07:58 PM
RE: ESi vs. RS
yea there are only apearance differences. I own a talon tsi AWD and my dad has a GSX and there are the same
TheEngineer Aug 1, 2006 10:02 AM
RE: ESi vs. RS
when you get the exhaust make sure you dont get piping bigger than stock
Michaels_RT Aug 15, 2006 12:18 AM
RE: ESi vs. RS
ORIGINAL: TheEngineer
Why on EARTH would you recommend that? The stock piping on a 2gen Talon NA with the 420A chrysler motor is 2". Thats AWFUL diameter. WAAAAAAAYYYYYY too small. Get yourself at LEAST 2.25", maybe even 2.5" cat back and a good long header and a CAI (AEM has shown the best results) and yuo will see that powerplant come to life.
TheEngineer Aug 15, 2006 10:37 AM
RE: ESi vs. RS
ok can someone else back me up on this one. On a NA motor you dont want to be putting bigger piping because the motor will not put out enough flow to be efficient for it. Also you will actually reduce the performance because you will reduce your backpressure in the piping. I cant find the article but there was a good write-up about this. I guess you could get away with 2.5" but i wouldnt go any bigger than that
paintballproam Aug 15, 2006 01:06 PM
RE: ESi vs. RS
yes engineer, you are right. You dont want to decrease the backpressure on a N/A car
Michaels_RT Aug 15, 2006 03:49 PM
RE: ESi vs. RS
No your WRONG. Both of you. You dont want to ELIMINATE your backpressure in an NA car, but bigger piping for better flow is a good thing...ESPECIALLY when the car has such undersized piping in stock trim as the 2gen NA Eclipse does. 2.5" is a MAXIMUM and when I DID IT on my ex's 99 RS Eclipse we had a GREAT results and was STRONG in the high end of the RPM range. The AEM CAI was KEY though towards helping develop power in that car. a exhaust with bigger piping doesnt ELIMINATE backpressure, just helps free up a little. Now putting a 3" exhaust on an NA 420a motor would probably be a bad thing. And sound like crap too. But a 2.25" or 2.5" is more than OK for decent power gains and well worth the money.
XTREME Aug 15, 2006 04:20 PM
RE: ESi vs. RS
If you replace your exhaust with a bigger diameter you will gain some top-end power but sacrifice quite a bit of low-end torque. For naturally aspirated engines such as yours I agree with Engineer on this one. If possible, you might find an exhaust with the same diameter that is smoother with less bends...that would be good.
