MN Engine Builder
MN Engine Builder
Hi everyone, I'm new to the Mitsu world, and I have a 94 3000GT I just picked up that needs some work. The timing belt broke, so I'm looking to do a full rebuild, and I was wondering if there were any recommendations for engine builders around the Minneapolis-St. Paul area. Thanks.
Greg
Greg
RE: MN Engine Builder
if the timing belt broke then you may only need to have the head rebuilt. Because usually what will happen is you will have the valves get bent. All you need to have that done is to find a machine shop that can do the work for you. Just look in the yellow pages or call a dealership and ask them where they send out thier head to be rebuilt
Thanks. Yeah I'm figuring a couple valves bent, and probably cracked a guide, but I won't know till its apart. I was just hoping to find someone experienced with re-assembling the engines. But I'll call around.
rmplstlskn
05-13-2022 03:49 AM
anko_kun
01-18-2006 12:52 AM
builder, builders, builer, bullders, engane, engine, forum, minn, minneapolis, mistubishi, mitsubishi, mn, motor
