``my 3000gt vr4 bogs when my boost hits 14lbs...what could it be??????
Old Mar 25, 2013 | 02:21 AM
chefnando's Avatar
Talking ``my 3000gt vr4 bogs when my boost hits 14lbs...what could it be??????
Hi, im new to this form, i just got a 1992 3000gt vr4, when i got it it was bogging when boost kicks in, found out it was because old owner was putting 87 unleaded, instead of 91, i put a octane boost in and it started to run great, but know its doing it again, when ever i punch it and boost kicks in, it starts to bog bad....any help well help
Old Mar 26, 2013 | 10:39 AM
the reek's Avatar
Make sure you are putting in premium and check your maf it might be going bad.
Old Mar 26, 2013 | 10:49 AM
chefnando's Avatar
how do you know if your maf is going bad, any signs
Old Mar 27, 2013 | 12:28 AM
the reek's Avatar
It will bog down like that and turbos won't work properly mine did it after I had the turbo restrictor pulled out and it just happened to go a few days later
Old Mar 30, 2013 | 10:15 AM
toddrs93's Avatar
Usually vacuum leaks or spark related. Replace plugs and wires and check vac lines
Attached Thumbnails ``my 3000gt vr4 bogs when my boost hits 14lbs...what could it be??????-image.jpg
Old Aug 10, 2013 | 11:25 AM
3KVT's Avatar
Default ^^^^
^^^^^ This.
apax
Jun 18, 2009 02:37 AM
apax
Aug 10, 2007 12:33 AM
GSXPimp
Jun 7, 2007 10:43 PM
Simss
Oct 7, 2006 10:36 PM
2001eclipse
Jun 19, 2005 05:31 AM
