'91 3000gt SL 5 spd not starting!
Old Feb 16, 2009 | 05:01 AM
troyie's Avatar
Default '91 3000gt SL 5 spd not starting!
Hello folks, I'm a new member here just now, and it seems I can get all the info to fix my 3kGT. So here's my situation my car is not starting at all Ikept my car in the garaged for about 6 months andbattery cableout because I know it will drain the power of my battery. Now I took my battery to recharge it and try to start my car but it fails me soI realized to check all related components for my ignition system such as, replacing my spark plug, fuel filter, and checked also wire spark plug but still ok, my starter also strong and still in good condition..when I try to start the engine cranking still ok but it's just no fire from my spark plug wires at all I am thinking that my ignition coil assembly or something else that causing not to give any fire.. So I was reading about the same issue that I have right now and trying to get the solution and get my car back on it's feet again.. I really miss my car running, so I'm asking all of your help and greatly appreciated for the response to me...
Btw I have "ECS" lights on for "tour" and "sport" at the same time well it supposed to be one at a time if I press the "ECS" button to which one I want to be on..but I guess it was giving me an error that's why my light are on at the same time due to my other suspension in the front passengerwhen they install my pre-cut spring and take out my suspension become damaged. Andafter all that installation itcausing the light to be on at the same time which is not good and must be repair asap or can damage the "ECU" as I read to this: htttp://www.ecmtogo.com/ECMTips2.htmbut so far I haven't touch it or unplug my ECU to see if it's really damaged or not I'm not really good in car but I know for sure can follow simpleinstructions. Do you guys thinkmy ECU is causing my car not to start also? HELP PLEASE!!! don't know what else to check...Thanks!
Old Jul 28, 2012 | 11:31 AM
3000gtskickass's Avatar
I just had similar starting issue with no spark... I replaced everything plugs wires coils ptu ... n after all that it was my ecu... it take 5 mins to check remove ur carpeted kick panels on console side 3 plugs into the ecu n 3 bolts to pull out... take off the ecu cover n examine the board mine had a xigar size burn in it I kno sumone that cn rebuild it cheap name is eric ryner on 3si.org n goodluck man id also get ur ecs looked at
TCS
Jul 11, 2010 10:06 PM
david76008
Sep 8, 2006 10:13 PM
Jdg784
Jan 22, 2006 05:01 PM
valjohnd
Mar 25, 2005 09:37 PM
valjohnd
Mar 25, 2005 09:33 PM
