For all eyes to see engine history
Old Jan 27, 2006 | 06:38 PM
jakster's Avatar
Default For all eyes to see engine history
"2-Bolt" to "4-Bolt" Short-Block Conversion
for the 3000GT/Stealth
by Jeff Lucius
First a bit of trivia. Mitsubishi made literally millions of the 6G72 engine since its introduction in 1988. This engine in its SOHC, normally-aspirated, 141-HP form was first used by Chrysler in the New Yorker in 1988. Later it was standard equipment in the LeBaron (the most notable version of which was the LeBaron TC in 1990, a combined Chrysler and Maserati effort). The SOHC 6G72 was used in the following cars:
ยท 1988-1989 Town & Country
ยท 1988-1994 Montero, D50, Mitsubishi Pickup
ยท 1988-1995 Voyager, Grand Voyager, Dynasty, Daytona, Duster
ยท 1988-1996 Caravan, Grand Caravan
ยท 1988-1996 Galant, Sigma
ยท 1989-1995 Acclaim, Spirit, Mighty Max, D-50
ยท 1991-1995 LeBaron, Saratoga
ยท 1992-1995 Diamante
Chrysler and Dodge continue to use the SOHC 6G72 (up to 200 HP and 200 lb-ft torque now) in the Stratus and Sebring coupes. Mitsubishi now uses this successful engine design in the 2000 and newer Eclipse models (SOHC), after having installed the DOHC version in some Diamantes. Unfortunately, the SOHC block is not the same as the DOHC block used in the turbocharged version of the 6G72 in the Mitsubishi 3000GT VR4 (1991-1999) and in the Dodge Stealth R/T Twin Turbo (1991-1996). Of all the vehicles listed above besides the 3000GT/Stealth, only the Diamante used the DOHC version of the engine. Bummer.
The DOHC 6G72 is an extremely strong engine, with an alloy steel block and aluminum alloy heads, and is capable of delivering well over 500 HP with turbocharging. As good as the first versions of the engine were, Mitsubishi decided to make the engine even stronger in 1993 models (starting with June 1992 production-date cars) giving it a 4-bolt main bearing cap girdle (the original used 2-bolt caps with stiffening stays on the middle 4 bolts) and a nitrided-steel crankshaft (the original was cast iron or mild steel). Mitsubishi made other changes, most significant of which was moving the crank and cam angle sensors from the left head (where it was user-adjustable for timing) and into the block (not adjustable). Major lower-engine parts that remained the same include the piston and pin assembly [MD307972 is listed as the standard-size replacement for all years] and the forged-steel connecting rod assembly [MD131329 is the only part number listed for all years]. Because the newer nitrided-steel crankshaft [MD318150] is listed as the replacement part for all years, it is possible to upgrade the "2-bolt" blocks with the better crankshaft (~$600-800 new). Clevite 77 bearings are an excellent choice to upgrade the stock main and rod bearings. As long as you have the engine apart, you might consider upgrading to forged aluminum pistons
I gathered the information below to assist the Z16A (turbocharged) 3000GT/Stealth enthusiast in converting the 1991-1992 "2-bolt" block to the 1993+ "4-bolt" block. This is not an engine swap and so does not involve or require any changes in the wiring harness or ECU. The 1991-1992 heads are retained, including the adjustable crank/cam angle sensor. The parts listed below are required to replace the 1991-1992 "2-bolt" block to a 1993+ "4-bolt" block, while re-using some of the old components. Supposedly, complete "4-bolt" blocks (short block assembly) can be purchased for a bit under $3000 from Mitsubishi dealers.
John Monnin has performed this 2-bolt to 4-bolt conversion and has put together an excellent set of web pages devoted to this topic. If you plan to do this conversion or are just curious, I highly recommend you read through John's web pages. He has a much more complete description than I have here.
Required items (be sure to verify part numbers with your dealer)
ยท 1993+ block (block with crank, rods, pistons, rings, bearings, caps)
[bare block with main caps, bolts, and plugs = MD187502;
short block assembly with crank, pistons, rods, bearings = MD326222 or MD314123]
ยท Gasket kit, engine overhaul (includes head gaskets, etc. also) (MD997670) [~$285]
ยท Oil pump, front crank seal and case (CAPS identifies as "Case Assy, Cylinder Block, Fr") (MD190982) [~$135]
ยท Oil pan (MD199562) [~$105]
ยท Rear (left) turbo oil return tube (MD196722)
ยท Rear crank seal & case (CAPS identifies as "Case Assy, Crankshaft Rr Oil Seal")(MD178606) [~$35]
ยท Timing belt lower cover (MD192109)
ยท Bracket, A/C Compressor Tension Pulley (required for engines produced before January 1992) (MB958144) [~$40]
ยท Stay, T/M Housing Front Lower Cover (in front, from engine to bellhousing, because newer oil pan is wider) (MD176109) [~$34]
ยท Maybe: Pulley, crankshaft damper - 9004.1-9103.1 used MD166815, 9103.2-9105.3 used MD176766, 9106.1 to end used MD177199
Optional items but strongly recommended (be sure to verify part numbers with your dealer)
ยท Timing belt (MD193874) [~$115]
ยท Timing belt tensioner (MD319040) [~$65]
ยท Timing belt tensioner pulley (MD140071) [~$25]
ยท Timing belt idler pulley (MD319022) [~$25]
ยท Water pump kit (MD972005) [~$85]
ยท Thermostat kit (MD174234) [$20]
ยท Power steering belt (MD172376) [$15]
ยท A/C belt (MB879764) [$25]
ยท Oil feed tube - rear turbo (MD174793, same for all years) [~$15]
ยท Oil feed tube - front turbo (MD161898, same for all years) [~$10]
ยท Oil return tube - front turbo (MD160039, same for all years)
ยท Cylinder head bolts, 12x102mm (MD065959) [~$60, qty of 16]
ยท Crank pulley bolt (MD151793) [~$7]
ยท Crank pulley bolt washer (MD096930) [~$2]
Acknowledgments
Some of the information presented here was gathered from various email lists, message boards, the Mitsubishi CAPS (parts lookup program), the 3000GT '91-'94 Parts Catalog, and vendor web sites. I would like to particularly thank Joe Gonsowski
_____________________________
Old Jan 28, 2006 | 03:14 PM
Default RE: For all eyes to see engine history
you could have just posted this on only one place. (double posting strikes again)...jk
Old Jan 31, 2006 | 01:50 PM
Silvertooth's Avatar
Lol yeah kinda cool though. Was a nice informational read.
Old Feb 2, 2006 | 10:29 PM
blasting_speed's Avatar
Very nice. Its so cool that people still dig these awesome cars. Too bad they're so expensive, but i'm never getting rid of mine.
catacami
May 1, 2007 11:58 PM
paintballproam
Mar 2, 2007 10:31 PM
mikem1
Jun 23, 2006 09:01 AM
jakster
Dec 21, 2005 09:28 PM
outlancer
Feb 21, 2005 03:04 AM
