Bluish Smoke, need help, please!
Old Jul 23, 2008 | 09:34 PM
crosbiegrad's Avatar
Default Bluish Smoke, need help, please!
I have a 93 SL model and when I accelerate I get a puff of blue-ish smoke out the exhaust. I'm guessing that the piston rings or seals are shot, is this an easy, albeit fairly labour intesive, fix? Any help or suggestions would be very welcome and appreciated
Old Jul 24, 2008 | 12:19 AM
Default RE: Bluish Smoke, need help, please!
Pretty labour intensive. Easier to change the motor.
Old Jul 24, 2008 | 07:55 AM
how about before you go and rebuild a motor or swap it. you take the time to do a compression and leakdown test. that will answer if it is really your rings ect
Old Jul 24, 2008 | 11:47 AM
dsm1990gsx's Avatar
^^^ Thanks you, do a dry compression test and then a wet compression test to see if you problem lies in the bottom end or head.
Old Jul 24, 2008 | 12:45 PM
Thats true.
It is probably only one part of one bank if it is in the head.
Old Aug 5, 2008 | 12:24 AM
mxmikie's Avatar
vss
Old Aug 5, 2008 | 01:39 AM
Joel_CA's Avatar
ORIGINAL: mxmikie
vss
Start with a compression test. If the numbers are good- don't even bother with the wet test. I agree that it is most likely the VSS.
JJ
flatmajor
Sep 29, 2008 02:03 PM
jc1984214
Aug 3, 2007 01:11 AM
paintballproam
Mar 8, 2007 07:11 PM
BrunoBoy650
May 31, 2006 07:39 PM
jap901
Jul 24, 2005 10:05 PM
