different VR4 weight
Ihave looked up the weight of different years of VR4's. They say 1991-1993s are 3803poundsand the 1994-1996 weigh a little bit lesserand the 1997 and up are 3737 pounds.
I was thinking since the (i think)96 -99 VR4's had chrome wheels might be heavy. So is the 3000gt VR4 weight calculated with its tires and wheels right? Does anyone know whatspecificallymakes the older VR4's heavier than the 97-99?
I think lighter plastics in the bodywork etc...
The wheels and tires i dont think will sway the bar that much.
Bottom line.. if you want the biggest weight difference... get on a treadmill lol
If you change to lighter seats... yes the car is going to be lighter [&:]
I dont see why you are so concerned about weight. If you care that much.... buy a 1g GSX and gut the interior. Your driving a tank... you cant shed weight from it.
Dont bother with seats man... waste of cash.
You can save a fair amount of weight by going with lightweight seats, I think I've read the drivers seat weighs around 65lbs. The wheels on the later models are 18's, I doubt they were lighter. The later gens didn't have the active aero. They may not have had the active exhaust either. That is probably why there is a 60lb difference.
They had fewer and fewer gimmicky accessories as the years went on. They lost active exhaust and active suspension in 95, but gained a power sunroof instead of the removable glass. in 1997 they lost the active aero, and then the weight varies by options (sunroof, etc).
you want a light weight twin turbo? buy a 96 stealth TT. No options, not even power antenna.
