different VR4 weight
Old Sep 3, 2007 | 01:42 AM
max3's Avatar
Default different VR4 weight
Ihave looked up the weight of different years of VR4's. They say 1991-1993s are 3803poundsand the 1994-1996 weigh a little bit lesserand the 1997 and up are 3737 pounds.
I was thinking since the (i think)96 -99 VR4's had chrome wheels might be heavy. So is the 3000gt VR4 weight calculated with its tires and wheels right? Does anyone know whatspecificallymakes the older VR4's heavier than the 97-99?
Old Sep 3, 2007 | 01:51 AM
Default RE: different VR4 weight
I think lighter plastics in the bodywork etc...
The wheels and tires i dont think will sway the bar that much.
Bottom line.. if you want the biggest weight difference... get on a treadmill lol
Old Sep 3, 2007 | 02:28 AM
max3's Avatar
if i got a 97-99 VR4that weighs 3,737 pounds while i take off the 18 chrome rimsand change to light seats etc. it would be lighter right.
Old Sep 3, 2007 | 02:41 AM
If you change to lighter seats... yes the car is going to be lighter [&:]
I dont see why you are so concerned about weight. If you care that much.... buy a 1g GSX and gut the interior. Your driving a tank... you cant shed weight from it.
Dont bother with seats man... waste of cash.
Old Sep 3, 2007 | 09:19 AM
thestealth's Avatar
You can save a fair amount of weight by going with lightweight seats, I think I've read the drivers seat weighs around 65lbs. The wheels on the later models are 18's, I doubt they were lighter. The later gens didn't have the active aero. They may not have had the active exhaust either. That is probably why there is a 60lb difference.
Old Sep 3, 2007 | 11:23 PM
3000gtman's Avatar
honestly i dont think the weight matters. a vr4 is still a fast car with 3800lbs. which i've definitely seen lighter weights on other sites.
Old Dec 15, 2007 | 10:16 PM
dorian7's Avatar
I don't think you will notice a difference. Once I heard that on average for every 100lbs you loose you gain a tenth of a second on the quarter mile.
Old Dec 16, 2007 | 08:35 PM
4g63419's Avatar
If you looking to buy the Stealth is also a great car weighing between 3,000-3,200 lbs.
Old Dec 18, 2007 | 10:35 AM
thestealth's Avatar
Not the TT models. They are just as heavy as the VR4's.
Old Jan 2, 2008 | 07:01 PM
Girly VR4's Avatar
They had fewer and fewer gimmicky accessories as the years went on. They lost active exhaust and active suspension in 95, but gained a power sunroof instead of the removable glass. in 1997 they lost the active aero, and then the weight varies by options (sunroof, etc).
you want a light weight twin turbo? buy a 96 stealth TT. No options, not even power antenna.
