ECM/ECU
Old Mar 30, 2007 | 05:11 PM
crzymanfitz's Avatar
Default ECM/ECU
the ECM is behind the radio right?? i think it's not telling my coils to spark the plugs. i'm getting no spark in the plugs.compression's fine and the timing is good. so i'm thinking new coil's or ECM (that's the same as the ECU right)??
Old Mar 30, 2007 | 05:38 PM
thestealth's Avatar
Default RE: ECM/ECU
Yes, it is behind the radio. You have to take off the two carpet pieces on the sides of the console to get to the mounting bolts.
What year and model is your car?
Did this just happen all of a sudden?
It could also be the PTU. It's the unit under the coil packs.
Old Mar 30, 2007 | 08:01 PM
Default RE: ECM/ECU
ok i got it out. i can't tell if it is burned out or not. how do i find out if it is the PTU??
Old Mar 30, 2007 | 11:17 PM
Default RE: ECM/ECU
If its burned out you will be able to smell it. And if you cant smell it then open it up and look. Usually you can tell just by looking at the inside of it
Old Mar 31, 2007 | 12:27 AM
Default RE: ECM/ECU
is that the same for PTU?
Old Mar 31, 2007 | 03:24 AM
thestealth's Avatar
Default RE: ECM/ECU
Scroll down to the bottom of this page to see what visible damage may look like.
http://www.stealth316.com/2-ecmremoval.htm
Look for any blackening or discoloration around the capacitors.
For steps on checking the PTU.
http://www.stealth316.com/2-pwrtransunit.htm
Old Mar 31, 2007 | 01:38 PM
Default RE: ECM/ECU
col thanks
superhuzzy
Jan 2, 2013 03:38 PM
nyc95gst
Jan 18, 2008 01:25 PM
martin
Jul 20, 2005 08:03 PM
martin
Jul 20, 2005 07:39 PM
cooley
Apr 2, 2004 03:03 PM
