ecs light problems
i got my tein lowering springs installed a couple days ago and now my ECS light keeps blinking non stop . i know the problem obviously has to do wit the installation of my springs . i took it back to the shop that did the installation and they check everything again but couldnt give me an solution so does anybody here know what i should do.
95 3000gt sl NA
95 3000gt sl NA
Check the electrical connections at the top of each strut and make sure they are firmly connected. Inspect the wiring in the harness going to each strut (especially the fronts) as the wiring may break over time causing an open in the circuit- this is more than likely to be your problem.
Joel, CA
Joel, CA
