ecs light problems
Old Mar 4, 2006 | 10:53 PM
3gtrican's Avatar
Default ecs light problems
i got my tein lowering springs installed a couple days ago and now my ECS light keeps blinking non stop . i know the problem obviously has to do wit the installation of my springs . i took it back to the shop that did the installation and they check everything again but couldnt give me an solution so does anybody here know what i should do.
95 3000gt sl NA
Old Mar 5, 2006 | 05:01 AM
Blk95SL's Avatar
Default RE: ecs light problems
Sorry mis read at first. Thought you changed out the Shocks and Struts.
Old Mar 5, 2006 | 05:49 AM
Joel_CA's Avatar
Check the electrical connections at the top of each strut and make sure they are firmly connected. Inspect the wiring in the harness going to each strut (especially the fronts) as the wiring may break over time causing an open in the circuit- this is more than likely to be your problem.
Joel, CA
Robinos1109
Feb 14, 2014 09:31 AM
19galant90
Feb 13, 2013 10:20 PM
Robinos1109
Jul 26, 2012 04:57 AM
oempartssupply
Dec 22, 2006 12:52 PM
zsero
Apr 24, 2006 03:54 PM
