ECU won't communicate
Old Mar 28, 2008 | 08:25 AM
lord_of_biscuits's Avatar
Default ECU won't communicate
I have a 92 non-turbo and I had a lot of trouble with different thinks not working right. Like the cooling fans never came on and the idle was about 2700rpms. So I replaced the ECU and everything started working great. But for some reason once it warms up and idles at 800rpms the check engine light comes on. I sent it to the shop and they said the ECU won't communicate. Anyone ever had this problem?
Old Mar 29, 2008 | 09:20 PM
rexbd's Avatar
Default RE: ECU won't communicate
I have a 94 stealth that once it got warmed up it would shut down. once it cooled off it would start again but once it warmed up it would quit running. After having carefully checked out it turned out to be the ECU. I had it rebuilt and all has been fine since.
Old Mar 31, 2008 | 10:23 PM
jgbrules's Avatar
hello!! did you have the ecu replaced with a rebuilt unit?? those things are pure crap!! i have installed rebuilt ecu's out of the box and car wouldnt crank, or had idle probelms, check engine light on.ect,ect,ect.... save your money and buy a factory unit. save you ALOT of headache!! if you can get a code out of it, more than likely it will be #41 injector. classic sign of craped out rebuilt ecu!! good luck!! greg...
qmlhcb
Nov 10, 2020 09:35 AM
nyc95gst
Jan 18, 2008 01:25 PM
buzzkill01
Nov 16, 2006 01:36 PM
DarkrealmX
Mar 14, 2004 01:55 PM
i_r_eddie
Feb 24, 2004 01:24 PM
