Engine cranks but wont start
Old Feb 10, 2008 | 07:11 PM
cod1ak's Avatar
Default Engine cranks but wont start
I have a 93 non turbo. Started the car yesterday, was runnung fine but the check engine light came on. I shut it down for 10 seconds and tried to start it again. She just cranks but wont fire. I pulled the codes and they are.....Crank angle sensorAND Top dead center sensor (cam sensor). Then per the manual, I checked the voltage and resistence values from the harness at the connectors. They both check out OK.
I find it hard to beleive that both could be bad. I know that the ECU, ignition module and coils are all tied in with this also.
I hate to start shotgunning parts at this and was wondering if anyone else has run accross this problem before. I had the ECU rebuilt about a year ago.
Any help would be appreciated.
Old Feb 10, 2008 | 07:15 PM
Default RE: Engine cranks but wont start
When my ignition control module went out there was no check engine light so scratch that. Its not the coils either.
I think its the crank angle sensor.
Old Feb 11, 2008 | 12:55 PM
Eggcellent's Avatar
I have kinda the same problem, and I changed the CAS. Still have the same problem even after changing the CAS, so now i'm looking into repairing the ECU.
Old Feb 11, 2008 | 05:01 PM
I can almost guarentee its no the ECU. Unless you smelled a rotten egg smell.
Old Feb 14, 2008 | 10:09 PM
jgbrules's Avatar
hello. i'd put money that its the ECU. pull off an injector connector on the front bank and put a noid light on it. when u crank it that noid light should blink bright and fast. if no pulse, and you know your crank sensor is good replace that ECU with a new one. REBUILT ECU'S ARE PURE CRAP. most come with a 30 day warranty. they go bad usually within 90 days. if you have a scanner go to the data section and pull up crank sensor then spin it over, if the crank sensor registers around 200rpm's thats normal and your crank sensor is fine.
Old Feb 20, 2008 | 07:46 PM
vr4girl's Avatar
ecu, maf sensor, orrr. :]
do you have any compression?
Old Feb 22, 2008 | 06:53 PM
VR4 wannabe's Avatar
have you checked all the basics? spark, fuel, compression? it could also be that your timing belt slipt a tooth. what all have you checked so far?
Old Feb 23, 2008 | 05:55 PM
cod1ak's Avatar
OK guys, I pulled the ecu and tested it in another 3000gt and it works fine. The timing marks are on the money. Checked spark and am only getting fire from the center coil (#2 and #5 cylinders). Do you think it could be the PTU or ignition module?
Thanks.
Old Feb 24, 2008 | 01:05 PM
Old Feb 24, 2008 | 04:23 PM
jermws's Avatar
I had a similar problem with the check engine light coming on. It was the engine coolant tempurature sensor, had the proper coolant level, just was telling the car it didn't, so i got that replaced. Also replaced the thermostat and gasket.
