GAS SMELL
Old May 21, 2006 | 07:16 PM
760_3000GT's Avatar
Default GAS SMELL
I JUST GOT MY 3000GT IS A 1995 SL BUT THERE IS SOMETHING I DON'T UNDERSTAND WHY DOES IT LEAVE A HEAVY GAS SMALL WHEN YOU I REV THE ENGINE ON THE PARKING LOT CULD IT BE THE GAS IS NOT PREMIUM (I HAD TO YOU USE THE CHEAPER ONE I WAS RUNNING OUT OF MONEY)OR WAHT ELSE COULD IT BE PLEASE HELP!!!!!!!!!!!!
Old May 21, 2006 | 07:30 PM
DeathCabForCutie's Avatar
Default RE: GAS SMELL
shouldnt be the grade of the gas...i use plus in my sl and ive never had a problem
you sure you dont have a leak somewhere??
Old May 22, 2006 | 11:52 AM
760_3000GT's Avatar
yeah i guesss is the gas grade i don't think i have a leak i would of notice already but goona check anyways
Old May 22, 2006 | 03:18 PM
760_3000GT's Avatar
i meant i don't think is the gas grade but just to make sure i ask
ORIGINAL: 760_3000GT
Old May 22, 2006 | 08:56 PM
Mine is sometimes a little stinky too. WHen was your last oil change? It will smell if you dont have the cat on it. If its a leak the ntake it to auto zone or something and they have a device that can find it in a second.
Old May 23, 2006 | 01:30 PM
760_3000GT's Avatar
i just bouth the car a couple of days ago and i don't know when was the last time they change the oil
Old May 23, 2006 | 04:41 PM
well... it should be a golden brown kinda colour... if its black then change it.
Old May 24, 2006 | 02:07 PM
760_3000GT's Avatar
its has the golden brown color so its not that, and it doesn't smell as bad anymore now
Old May 24, 2006 | 06:27 PM
Its nothing really. If its a leak then they will find it in about 15 seconds with a little device. Most turbo cars are a little stinky anyway.
Old Jun 21, 2006 | 11:40 PM
bugjules84's Avatar
So quick question...I have a 1991 mitsh3000gt sl, however I don't know too much about these cars, but anyway mine has duel exaust...does yours? You see because the previous owner had installed the new duel exaust and when they were installed they were positioned too high to my fuel inlet hose, which caused the hose to melt and I had to replace it. Although I replaced the hose, it still continues to smell like gas because it is slowly melting again...until I can get my exaust lowered, I will continue to have this problem...so you may wanna check the fuel inlet hose, you may have the same issue??
