-   Mitsubishi 3000GT (https://mitsubishiforum.com/forum/mitsubishi-3000gt-12/)
-   -   Grinding/humming noise (https://mitsubishiforum.com/forum/mitsubishi-3000gt-12/grinding-humming-noise-28657/)
3000gtkid Aug 5, 2008 10:08 AM
There a 1991 3000GT SL 5-Spd 141,000 miles. With new clutch, new transmission. But theres an loud huming/grinding noise coming from the rear of the car. I was test driving it and when sitting in the passenger seat i felt shaking from the right rear tire. I drove it and it was great but the noise was loud what could it be. Thanks
Joel_CA Aug 6, 2008 08:42 AM
RE: Grinding/humming noise
Grinding and humming are 2 completely different sounds. You'll need to be more specific as to what you are hearing. Grinding can be coming from the brakes or a completely failed wheel bearing that had fallen apart. Humming- could be from your tires or from a wheel bearing that has failed but is still together. Either of them can be determined with a simple inspection.
JJ
3000gtkid Aug 7, 2008 10:24 AM
It's more of a loud deep humming noise
EMC 3000GT Aug 11, 2008 04:56 PM
Check your lug nuts.
dsm1990gsx Aug 11, 2008 06:56 PM
I would be its a wheel bearing. Does the noise change when you turn left or right?
3000gtkid Aug 13, 2008 06:27 PM
Yes it is a wheel bearing there fixing it for free before i buy it
