Grinding/humming noise
Old Aug 5, 2008 | 10:08 AM
3000gtkid's Avatar
Default Grinding/humming noise
There a 1991 3000GT SL 5-Spd 141,000 miles. With new clutch, new transmission. But theres an loud huming/grinding noise coming from the rear of the car. I was test driving it and when sitting in the passenger seat i felt shaking from the right rear tire. I drove it and it was great but the noise was loud what could it be. Thanks
Old Aug 6, 2008 | 08:42 AM
Joel_CA's Avatar
Default RE: Grinding/humming noise
Grinding and humming are 2 completely different sounds. You'll need to be more specific as to what you are hearing. Grinding can be coming from the brakes or a completely failed wheel bearing that had fallen apart. Humming- could be from your tires or from a wheel bearing that has failed but is still together. Either of them can be determined with a simple inspection.
JJ
Old Aug 7, 2008 | 10:24 AM
3000gtkid's Avatar
It's more of a loud deep humming noise
Old Aug 11, 2008 | 04:56 PM
EMC 3000GT's Avatar
Check your lug nuts.
Old Aug 11, 2008 | 06:56 PM
dsm1990gsx's Avatar
I would be its a wheel bearing. Does the noise change when you turn left or right?
Old Aug 13, 2008 | 06:27 PM
3000gtkid's Avatar
Yes it is a wheel bearing there fixing it for free before i buy it
JudgeLeigh
Mar 19, 2011 12:23 PM
Nubiebubie_GSX
Mar 14, 2007 07:33 PM
rallyendeavor
Jul 20, 2006 11:22 PM
mapa244
Jul 30, 2005 07:05 PM
Keylewm
Jun 16, 2005 08:09 PM
