GT issues
Old Jan 28, 2008 | 12:36 PM
Eggcellent's Avatar
Default GT issues
Hello Everyone J
I got a diagnostic ran on my 1992 3000gt SL, and these are the codes that came up, along with a description.
PO11 – O2 sensor
PO12 - air flow meter
PO14 – TPS signal out of range
PO21 – Temp sensor out of range
PO31 – Knock sensor circuit
PO43 - EGR System
PO53 – ign signal or coil #3 and 6
PO82 – intake air
PO61 – ELC-4AT error (torque reduction)
Can anyone tell me about how much this all should cost to fix? Also, is there any order of importance at this point? Would any of these issues be an easy fix? Any help is appreciated, as I determine if I want to put any money into this car.
Old Jan 30, 2008 | 11:29 AM
thestealth's Avatar
Default RE: GT issues
You pulled all those codes at one time? I would check the caps on the ECU before you try fixing all of that.
Old Jan 30, 2008 | 05:46 PM
Eggcellent's Avatar
Yes...one diagnostic run. You have any screen shots, or tuturials on the ECU...Honestly, I don't even know where to locate it.
Old Jan 30, 2008 | 05:56 PM
thestealth's Avatar
http://www.stealth316.com/2-ecmremoval.htm
http://www.stealth316.com/0-home.htm Bookmark this page and use it. Just about everything you'll need to know will be there.
Old Feb 1, 2008 | 11:39 AM
Eggcellent's Avatar
Awesome!!!! Thank you very much
b_bruton77
Jun 23, 2004 10:04 AM
b_bruton77
Jun 19, 2004 03:28 PM
Arcueil
Jun 4, 2004 05:39 PM
cooley
Apr 1, 2004 01:59 AM
DarkrealmX
Feb 15, 2004 07:47 AM
