GTO twin turbo vacuum leak
Old Jul 25, 2007 | 11:59 PM
freakosaurus's Avatar
Default GTO twin turbo vacuum leak
So I got my gleaming polished intake plenum today from 3sx...swapped it out with my old one, and now my car runs like a pile. It stalls if you dont give it gas. I noticed that when I romped on it though, that my boost guage would drop dramatically as my turbos spooled. Ok, so vaccuum leak I figured. Theres some sort of sensor tagged onto a line coming from the top of the plenum itselft (it's also 'tee'ed' to go to my boost guage). Its mounted on the friewall close to the battery, and has 3 outets. Is this for the factory boost guage? anywho, I noticed that after hooking that up, there was an extra port on it that felt like vaccuum on the bottom (facing down towards the engine). Im pretty sure that I hooked it up right, but does anyone have any info about this piece and where it is supposed to go?
Old Jul 26, 2007 | 08:49 AM
thestealth's Avatar
Default RE: GTO twin turbo vacuum leak
You must have forgot to hook up one of the vac. lines. Can you get a picture of the open port that you speak of?
The factory boost gauge does not read vacuum/boost. It gets its information from the ECU, it only shows where the ECU "thinks" the boost would be. It is more of a engine load guage than a boost guage.
Old Jul 28, 2007 | 01:27 AM
ok so I got my baby running. I really had no idea that the EGR valve block plate (on the firewall side of the plenum) had a gasket. I looked at my old plenum and noticed a mashed ugly little piece of metal that used to be a gasket. Freighted a new one in from cali overnight, slapped er on, and away I go! Yay, problem solved for under $10! that's not common with these cars hahah.
Old Jul 28, 2007 | 08:34 AM
thestealth's Avatar
...I love it when it's an easy (and cheap) fix.
TotalEclipse
Feb 21, 2012 06:53 AM
Dibdob11
Oct 10, 2011 08:14 AM
Janarris
Dec 14, 2007 04:47 PM
BrunoBoy650
1st Generation
May 2, 2006 09:26 PM
