help on a sensor
Strange enough, I'm right anyhow, if yours is in the same location of the VR-4s that is ![Big Grin](https://mitsubishiforum.com/forum/images/smilies/biggrin.gif)
![](http://www.supercar-engineering.com/rubberducky/3S/Pics/TT/EngPics/DSC00088.jpg)
It's the one on the far right sprocket. Do you see the 3 wire plug just under the sprocket?
Wait a minute...are you looking for the CAM or the CRANK angle sensor? The CAM and CAS is the same thing.
Whichever you're looking for, the pic shows both. Again, the cam sensor is on the cam sprocket and the crank sensor is on the......crank.
That is the cam and crank sensors on the 2nd gen engines (93+)
On the 1st gens the crank/cam sensors is one unit on the passenger side of the engine, rear bank, front cam.
http://www.stealth316.com/2-cas-91-92.htm
ORIGINAL: thestealth
Crzymanfitz, the Cam sensor is the one on the top. Do you see that cam sprocket/gear that looks different than the first 3? That's where the sensor is located. See that black object with wires running to it, just under the gear teeth of the last sprocket, running almost parallel to the timing belt?
