JDM VR4 motor swap help
Old Jun 23, 2009 | 04:45 PM
xricer's Avatar
Default JDM VR4 motor swap help
Into a 1996 3000gt. the motor came witout the turbos,so ill have low compression pistons with no forced induction,anyone know around how much it would cost to turbo it and would it run better turboed?
And if it has low compression pistons does that mean i could use a big shot of nitrous
Old Jun 23, 2009 | 06:12 PM
Girly VR4's Avatar
low compression = slower. you should have just gotten an n/a engine, or a vr4 engine with the turbos.
Old Jun 23, 2009 | 07:20 PM
xricer's Avatar
i didnt know it was a vr4 motor my dad orderd it anfd he had no idea and i forgot to tell him,i know low compression = slower but whats the best sugestion that i should do.
Old Jun 24, 2009 | 12:44 PM
Girly VR4's Avatar
In all honesty, I would sell it and get an n/a engine. You can probably sell that engine for around $1200-$1500 depending on the mileage, etc. and you can pick up an n/a engine for around $800-1000, depending on the mileage, year, etc, etc.
Old Jun 24, 2009 | 03:30 PM
xricer's Avatar
its already in,soooo probably gonna keep it and do something with it.
Old Jun 24, 2009 | 04:08 PM
Girly VR4's Avatar
twin turbo it
Old Jun 26, 2009 | 11:14 AM
jntw1nturb0's Avatar
you can get stock vr4 turbos and manifolds for a decently low price if they are used. it would run a lot better with turbos cuz it was built for boost. without turbos it would not have much power due to lower compression. nitrous can be used but it wears out your engine faster. if you want good n/a power and torque go with the 6g74 (3.5 litre) engine. it is a direct drop in to the n/a 3000gt with a little modification to the exhaust due to higher deck height and the heads are alittle farther apart cuz of that. my buddy has the 3.5 in his 94 3k and it is fast. but if you do the 6g72tt swap then it would be alot better to have turbos. or what you could do is do a single turbo install on it and it would be beasty as heck
Old Jun 26, 2009 | 11:47 PM
xricer's Avatar
thats what i was looking to do.single turbo
Old Jun 27, 2009 | 08:41 AM
for a single turbo id look into a gt40 or gt42 series turbo
STI_LLC
Jun 25, 2012 08:50 PM
whiteivory
Feb 17, 2012 04:28 PM
xricer
Jun 26, 2009 11:08 AM
bigmacak22
May 21, 2009 01:28 AM
