keyless
Old Dec 11, 2006 | 10:30 PM
mitsuant's Avatar
Default RE: keyless
its a valiant system. with a remote start, keyless entry and trunk release.
Old Dec 11, 2006 | 10:56 PM
ictponder's Avatar
Default RE: keyless
I can't find an installation manual for that. If you can, print out the diagram I pasted and follow the directions in the install manual, be sure to check the polarity of the parking lights or they wont work, the diagram i gave you shows the polarity trigger each wire needs to see. Also, paste the info for the wire harnesses on here and I can help you.
Old Dec 11, 2006 | 11:11 PM
ictponder's Avatar
Default RE: keyless
n5926g: You don't want an aftermarket fob? Here is the info for the 96, I'm not sure how to program an OEM remote and I've looked but no info so far.
Old Dec 12, 2006 | 12:09 AM
n5926g's Avatar
Default RE: keyless
Thanks loads for the printout,Im pretty much a stickler for OEM,and this aftermarket remote is kinda cheap,but it does work.If its ok with you,im gonna wait until the new OEM reciever arrives,and see if it indeed works,if not Ill likely gat back with you with some specifics of this unit,and discuss what options ive got.Like I said,it locks and unlocks the doors,but thats all.Ive also got a weird issue with the existing electric locks,they actually activate about 4 times in rapid succession when I use the aftermarket remote system.....Thanks again.
Old Dec 12, 2006 | 02:13 AM
ictponder's Avatar
Default RE: keyless
You know, a Viper 5900 has a 1 mile range with frequency hopping and 2-way LCD keyfob which tells you if your vehicle actually remote started and also tells you where on your vehicle is being tampered with if it's actually being broken into. Since I work for a distributor I got it for $180, not sure if I can get more but I could check. We usually charge about $700 to install one.
Viper 5900 (p/n 5301V) MSRP $659.99
2-Way Security System / Remote Start System with Responder SST Technology
* 6 channel remote start/security/keyless entry system
* Confirms commands and system triggers on the transceiver LCD screen
* Clone-SafeĀ® Code-HoppingĀ®
* Parking Light Flash
* FailsafeĀ® Starter Kill
* Anti-Grind
* StingerĀ® DoubleGuardĀ® Shock Sensor
* RevengerĀ® Six-Tone Siren
* Bright Blue LED Status Indicator
* Miniature XCRS (Extreme Capacity Relay Satellite)
* Defroster Output
* Built-in Turbo Timer
* Dome Light Supervision
* Comfort Closure
* 4 Auxiliary Outputs
* Horn Honk
* Includes One 2-way Responder SST Transceiver
OEM is nice but ya can't argue the benefits of something like that package
Keyless Remotes
May 9, 2005 07:25 PM
tmh1
Nov 20, 2004 10:32 AM
JazAddict
Jun 22, 2004 09:50 PM
Keyless Remotes
May 5, 2004 11:49 PM
mit_ucla
Nov 5, 2003 07:40 PM
