light out
Old Dec 9, 2006 | 01:13 AM
mitsuant's Avatar
Default light out
hey yall one of my runnin lights just went out the prob is that i dont have the manual. so i dont know how to replace the bulb i looked and there is no light plug there, so where is it?
Old Dec 9, 2006 | 10:53 AM
n5926g's Avatar
Default RE: light out
If its a 3000gt(which I assume it is) ,pull straight out on the outer lens,there will be 2 screws holding the inner lens in,remove these two screws,and youll have access to the bulb,itll be I think a 55w lamp.if one has gone south,the other is likely soon to follow,Autozone has them for about 4 bucks apiece.....
Old Dec 10, 2006 | 09:11 PM
mitsuant's Avatar
i tryed to get the back lens off to get to the light but it seems stuck. is there a special way to take it off?
Old Dec 10, 2006 | 09:21 PM
n5926g's Avatar
If memory serves,once you unscrew the long screws,you should be able to just pull straight out,there will be two wires,one ground,and the other will be the hot feeding the socket,might have to wiggle it around a bit.mine were out of the car when I got it,and in the trunk along with alot of the other stuff the previous idiot took off....[sm=dontgetit.gif]
[IMG]local://upfiles/9786/27280816C4BC4FB8916FE373026600B1.jpg[/IMG]
Benpentz
Dec 7, 2012 03:55 PM
shaolin
Feb 15, 2011 07:48 PM
ftamiguel
Nov 9, 2010 11:16 AM
Jarreddl
Apr 27, 2008 08:27 PM
serenabkhan
Nov 23, 2007 05:44 PM
