Motor Mounts
Old May 24, 2008 | 04:17 PM
Ralliart3000's Avatar
Default Motor Mounts
a quick question .. can my solid motor mounts fu*k up my car because its vibrating more at idle ???
Old May 24, 2008 | 04:39 PM
isiah's Avatar
Default RE: Motor Mounts
no, i don't believe that it will mess anything up.. i think that's just something that you have to deal with. you should post this up on 3si.org/forum or search it or something.
_isiah
Old May 24, 2008 | 08:12 PM
No it won't mess anything up
Old May 25, 2008 | 04:20 AM
silvercoupe97's Avatar
It should be expected to feel more vibration with solid motor mounts.
Were you surprised that you feel the motor vibrations now? The stock, rubber centered, mounts served two purposes, one is to dampen motor vibrations and the obivous..hold the motor in place.
Old May 27, 2008 | 08:31 AM
no i knew it would vibrate more idc but i was just wondering and also its just that my brother was being a dick and annoying me about it so i posted this to rub it in his face .. and another quick question if u guys dont mind .. i know my rotors are warped but my stearing wheel shakes a bit as im driving? and when i hit the gas all the way when im stopped the car pulls a bit to the side i think thats power steering though?!?!?
Old May 27, 2008 | 11:56 AM
No thats alignment. And for God's sake get the brakes done.
Old May 29, 2008 | 02:29 PM
got the brakes put on yesterday no more shaking when im braking .. but my cuzine told me that both of the boots where riped on the ball joints could that be why its shaking when i drive ? dont worry im going to get the alignment done also but i dont think thats it .. its just theres no point if the ball joints are messed up also because dont you have to align the car when u change them as well?
Old May 29, 2008 | 04:10 PM
ORIGINAL: Ralliart3000
Yeah, there really is no point in getting it aligned now only to get it aligned again after replacing the balljoints. I would get those done fairly soon, especially if they affect wheel position in terms of steering.
Old May 30, 2008 | 11:46 AM
The boots being torn has nothing to do with the shaking, but if you don't get them replaced then you will break the joints
Old Jun 3, 2008 | 01:33 PM
i replaced both of them and the shakyness went away and oddly on the same day i put a cold air intake and i made a custom 2.5 inch dual catback exhaust system and my car dosent vibrate anymore with the solid motor mounts ....
