Motor Rebuild( Boring the cylinder walls )
Old 08-21-2007 | 05:27 PM
NiceVR4's Avatar
Default Motor Rebuild( Boring the cylinder walls )
Hey I'm saving up for a motor rebuild new rods ,pistons, and oversived valves 1mm over maybe 2mm's, but I havent decided whether or not
to go oversived pistons I know that one of the downsides is theres a larger chance of cracking the cylinder walls so I guess Im
asking is there anymore downsides to boring the cylinder walls on 3s or just anyother car and good or bad idea ?
-thanks
Old 08-21-2007 | 05:39 PM
Default RE: Motor Rebuild( Boring the cylinder walls )
Well the only downside is the lower RPM limit. The stock limiter is just fine... but on a built motor (stock bore) you can achieve a lot higher RPMs... and with a bore.. it has to be a little lower.
Old 08-21-2007 | 11:13 PM
NiceVR4's Avatar
I didnt know that so I should just stick to stock stock bore thanks but will a larger displacement also have less turbo
Old 08-21-2007 | 11:15 PM
No.. larger displacement will make the turbos kick in earlier.
If you arent using an aftermarket ECU then the factory rev limit will be the same on either bored out or stock bore...what i meant to say.. was the max of the stock bore will be higher... reason being.. less moving mass...but if your using the stock rev limiter.. then it doesnt matter
Old 08-22-2007 | 12:41 AM
NiceVR4's Avatar
Oh crap sorry about that last reply typo I was trying to say less turbo lag
But i think Ima stick with wuth the stock bore now thanks plus I'll save a few bucks too
Old 08-22-2007 | 09:59 AM
thestealth's Avatar
You can't punch these engines out very much, the most you would end up with is 3.1L. I believe the differences in lag and rev limit would be negligable.
Old 08-22-2007 | 11:39 PM
NiceVR4's Avatar
Yea plus I was thinkin the biggest turbos I can go right mow is 15g maybe td04-16g and boring out the cylinder walls may be
overkill
Old 08-24-2007 | 11:51 PM
3000gtizzle's Avatar
im doin the same thing but im stickin with N/A im just gonna go with a short stroke long rod setup
Old 08-24-2007 | 11:52 PM
Well, i hope you know that your not going to get a big power gain... at all
Old 08-25-2007 | 12:00 AM
im not really goin for a huge power gain but ill be able to keep it goin at high rpms all day without hurting the engine and in turn making alonger power band
