Motor Rebuild( Boring the cylinder walls )
Hey I'm saving up for a motor rebuild new rods ,pistons, and oversived valves 1mm over maybe 2mm's, but I havent decided whether or not
to go oversived pistons I know that one of the downsides is theres a larger chance of cracking the cylinder walls so I guess Im
asking is there anymore downsides to boring the cylinder walls on 3s or just anyother car and good or bad idea ?
-thanks
-thanks
Well the only downside is the lower RPM limit. The stock limiter is just fine... but on a built motor (stock bore) you can achieve a lot higher RPMs... and with a bore.. it has to be a little lower.
No.. larger displacement will make the turbos kick in earlier.
If you arent using an aftermarket ECU then the factory rev limit will be the same on either bored out or stock bore...what i meant to say.. was the max of the stock bore will be higher... reason being.. less moving mass...but if your using the stock rev limiter.. then it doesnt matter
