Multiple Questions
Old Aug 19, 2005 | 06:16 PM
sfitz94's Avatar
Default Multiple Questions
I was wondering if anybody could help me out with the following questions regarding my 95 3000gt:
1) Does anyone know how to remove sun damage from the headlights?
2) Does anyone know how to change the bulb behind the climate control
3) Does anyone know how to get rid of bubbles in the door panel?
4) Does anyone know of a cheap place to get a new antenna? The motor still works I believe. It makes noise still.
Thanks for any help you might able to offer.
Old Aug 21, 2005 | 03:45 PM
m3kgt_99's Avatar
Default RE: Multiple Questions
Here it is...
1 Get plastic polish and buff out your headlight
2 Take out the 3 screws and take out your climate control and pop off the black front face and replace the bulb.
3 don't know what you mean by "bubbles"
4 look in the other post about the antenna. Make sure you don't repost things... they are probably already there.
Old Aug 21, 2005 | 04:58 PM
sfitz94's Avatar
Thanks for the help. The "bubbles" are in the door paneling. The vinyl has started to come up, causing little pockets of "bubbles." As for the climate control panel, some of the **** won't come off, and I am afraid that they might break if I pull too hard.
I just polished and buffed out my headlights, and they look a 1000 times better.
Thanks again.
Old Aug 22, 2005 | 12:22 AM
...GTSL...'s Avatar
as far as the bubbles. i have them too and as far as i know there's nothing you can do other than to replace the vinyl. all the bubbles are is the vinyl expanding and contracting because of heat and cold and the glue coming off. maybe someone with interior refurbishing experience could give soem tips, cause id be interested too.
~kenny
Old Aug 23, 2005 | 08:57 AM
m3kgt_99's Avatar
I pulled those **** before, and they were very hard to come out, but if you pull hard enough and wiggle them, they should comeout.. I have done it before. go to my signature on cardomain and look
Streetz25tl
Jul 19, 2014 09:50 AM
Nickv93
Oct 14, 2013 06:16 PM
vr4gto
Dec 19, 2012 08:08 PM
Akmikek
Jan 31, 2009 07:41 PM
DJ SlipStream
May 8, 2005 04:55 PM
