Need Help!
Old Jul 19, 2004 | 02:58 AM
saynotovtec's Avatar
Default Need Help!
I just recently bought a 3000gt. the man i bought it from told me that he replaced the water pump just the week before i purchased it and when he did, he put the timing belt on out of time. he said it was only one tooth out of line. but when i looked at the timing belt it was way more than one tooth off. the car is a 1991 SL and has 112000 miles on it. when i bought it i replaced the air and fuel filter, spark plugs and wires, battery, brake and power steering fluid, oil and oil filter, i need to know the chances that i did any serious injury to the top end of my car, i called three mechanics, two of which were friends of the family, and all three basically told me that they would rather shoot themselves in the foot than deal with a mitsubishi that has been ran with the timing off. any help or insight as to the chances that i bent the rods or even worse damaged my pistons would help greatly. thx in advance.
Old Jul 21, 2004 | 12:05 AM
Default RE: Need Help!
No one can help?
Old Jul 21, 2004 | 10:42 AM
wildwest's Avatar
how far off is it... hows it runnin?
Old Jul 21, 2004 | 10:24 PM
its off really bad like half the rotations of the cams, it doesnt run well at all, it hesitates at increased throtle input and when idling it regularly backfires and almost dies
Old Jul 21, 2004 | 11:14 PM
Prophet's Avatar
Take it in and have the timing adjusted. If your timing is off you can run into serious problems that may led to a blown motor. Timing is nothing that should be played around with. When you adjust the timing that maybe the only problem. Your first step should be getting it back on time.
Old Jul 22, 2004 | 11:01 PM
If by chance I do have to replace the heads, are there any aftermarket heads you can any of you can readily think of that would be a good replacement? I wouldn't mind using this as an excuse to make it faster if at all possible. My girlfriend hates the car already, especially since I upgraded the clutch and she can barely press it down now. what a weakling lol.
Old Jul 23, 2004 | 12:34 AM
thestealth's Avatar
Dynamic Racing and 3SX Performance are two reputable shops.
http://www.dynamicracing.com/customer/home.php
http://www.3sxperformance.com/
Look on 3si.org for more information about upgrading your ride.
http://www.3si.org/forum/index.php?
Good luck with your car.
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
