need help
Old Sep 5, 2007 | 04:57 PM
luisan45's Avatar
Default need help
HI all, I have a 93, the timing belt broke and there might be damages to the engine. I want to know if anyone knows how much this would cost to repair and if anyone has had the same situation. Should I repair or give up on the car???
Old Sep 5, 2007 | 05:09 PM
Default RE: need help
All depends what is damaged. Removing the head will tell you. If just the head is damaged, thats okay. If the pistons are badly damaged.. then forget about it
Old Sep 5, 2007 | 05:12 PM
luisan45's Avatar
I took the car to a mitsu dealer and they want to charge 600 just to look at the engine.....
Old Sep 5, 2007 | 06:25 PM
Tell them to F UCK themselves. You can do it yourself... its not hard
Old Sep 6, 2007 | 11:25 AM
luisan45's Avatar
Ok, I was told that the valves are bent... is this serious? they are giving me a ball park figure of over 3,000 to fix it. what do you suggest?
Old Sep 6, 2007 | 11:32 AM
Thats waaay over the top
Well if the valves are bent that means they hit pistsons... i guess they werent damaged that bad... because if they were at all im sure they would be telling you that you needed to replace the motor.
My advice to you is to look on eBay or something and findtwo 6G72 (make sure its the same non turbo/turbo etc) heads. They really arent that expensive. Orif the head isnt actually damaged.. and just the valves.. you can find a head rebuild kit for it andjust repalce the valves... most likely the head needs to be replaced. Then you will need 2 head gaskets and 2 sets of head studs... and obviously a new timing belt.
All together in parts should be a little over 1k (depending on how well you search for parts). To be entirely honest... it might be worth you having a shot at this yourself. Will save you cash and you will learn something. If you chose to do that.. invest in a Haynes or Chiltons manual.
Or, you could just pay the 3 grand and let them do it.
Old Sep 6, 2007 | 12:17 PM
thestealth's Avatar
Invest in a official service manual...screw haynes/chiltons...
Old Sep 6, 2007 | 01:52 PM
LOL or do that
Old Sep 6, 2007 | 02:13 PM
3000gtman's Avatar
buy a brand new engine for a 1/3 of the price that theyre telling you will cost to fix it and put it in. it'll save you money and you'll most likely have less miles. the non turbo 6g72's are pretty cheap.
Old Sep 6, 2007 | 02:20 PM
Thats true...good call.
