need help converting
Old Sep 16, 2006 | 06:13 PM
3000GT_R34SPEC's Avatar
Default need help converting
does anyone know how much it would cost and wht i would have to do to convert a '94 3000gt from fwd to awd
Old Oct 11, 2006 | 07:32 AM
Blakesmitsu's Avatar
Default RE: need help converting
why not just get a VR-4
Old Oct 11, 2006 | 04:00 PM
Xavier's Avatar
^ agreed
Old Nov 28, 2006 | 07:53 AM
Mr.3000's Avatar
Maybe because the man wants to have fun building up his car. Yea it will cost more but there is nothing like building a car. You will need the read sub frame, the VR4 Transmission, drive shaft and a few other parts. It will be expensive unless you find a junk yarded VR4 to get parts from. Also, did you do a Twin Turbo conversion yet or have the TT engine in your car already? If you don't you are going to add quite a bit of weight switching your car to AWD which means your NA engine will not get you moving very fast. If you are worried about being able to lay down power with your FWD don't worry it can be done...prob for alot cheaper than making your car an AWD. You will need to get a Limited Slip Differential either from kormex or Quaife. They are expensive but will get the power to the ground. Also you need to stiffen your engine mounts to get rid of that ugly wheel hop.
Sophie Hemmington
Dec 6, 2023 12:06 AM
mxthor44
Jun 8, 2006 04:31 PM
3kforlife
Mar 27, 2006 03:44 AM
jonzie04
Mar 23, 2006 12:29 PM
ictponder
Mar 8, 2006 01:03 AM
