now im confused...HELP
Old Jan 26, 2011 | 09:05 PM
3000gtluke's Avatar
Default now im confused...HELP
ok,i have a 95 3000gt automatic.we replaced the end clutch but it still has no overdrive.park,reverse,neutral,all work fine,no slipping or anything.when you put it in low,2nd,or drive it seems like its stuck in 3rd gear.it doesnt shift and takes off slow and at 55mph runs around 3000rpm.i dont know what to check next.any help asap would be greatly appreciated.thanks
Old Jan 29, 2011 | 07:35 PM
'95-3000gt's Avatar
it could be your trans filters on too tight.
Old Jan 30, 2011 | 07:34 AM
Girly VR4's Avatar
sounds like they didn't replace one of the seals. Those exact issues will arise if that seal is not replaced/installed.
Old Jan 30, 2011 | 10:38 PM
3000gtluke's Avatar
what seals are you referring to?
Old Jan 31, 2011 | 09:29 AM
Girly VR4's Avatar
in the transmission.
Old Feb 1, 2011 | 11:19 AM
963000gtvr4's Avatar
check all of your seals and make sure everything is snug not to tight
edaddik
Nov 24, 2005 02:27 PM
white99rs
Sep 19, 2005 07:39 PM
vinceaton
Jul 7, 2005 07:41 PM
Cbluefrost
Apr 17, 2005 11:35 PM
